跳转到主内容
Sony Vaio SVE171C11L Motherboard Replacement
你所需要的
  1. Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Turn the laptop facedown.
    • Locate the battery compartment at the top of the laptop base. You will see two tabs on it.
    • Push the two tabs up to release the battery. Set it aside.
  2. Sony Vaio SVE171C11L Motherboard Replacement: 步骤 2 中的图像 1,2 Sony Vaio SVE171C11L Motherboard Replacement: 步骤 2 中的图像 2,2
    • Rotate the laptop so the empty battery compartment is now at the bottom.
    • Remove the two screws that secure the hard drive cover using a T5 Torx screwdriver. Set it aside.
  3. Sony Vaio SVE171C11L Motherboard Replacement: 步骤 3 中的图像 1,2 Sony Vaio SVE171C11L Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the three screws securing the hard drive disk in place.
    • Use the blue ribbon attached to the hard drive disk to carefully remove it from laptop. Set it aside.
  4. Sony Vaio SVE171C11L Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove all screws holding the back panel from the laptop.
    • Carefully pull up the back panel to remove it.
  5. Sony Vaio SVE171C11L Motherboard Replacement: 步骤 5 中的图像 1,3 Sony Vaio SVE171C11L Motherboard Replacement: 步骤 5 中的图像 2,3 Sony Vaio SVE171C11L Motherboard Replacement: 步骤 5 中的图像 3,3
    • Remove the cables from the fan and unscrew the heatsink.
    • The heatsink has many metal pieces jutting out from its base and is located under the fan.
    • Carefully disconnect the tabs on the edges of the motherboard.
    • Unscrew the screws holding the motherboard in place. Set them aside.
    • On the underside of the motherboard, disconnect the keyboard from the motherboard.
    • Once ALL cables are disconnected, carefully remove the motherboard.
结论
Edward Briseno
于09/26/22注册
893 声望
创作了6篇指南
团队
CSU Los Angeles, Team 6-3, Adachi Fall 2022 CSU Los Angeles, Team 6-3, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S6G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 14
总计 327
