跳转到主内容
Sony Vaio SVE171C11L Hard Drive Replacement
你所需要的
  1. Sony Vaio SVE171C11L Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE171C11L Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
    • Use your left hand to push up the left tab to release the battery.
  3. Sony Vaio SVE171C11L Hard Drive Replacement: 步骤 3 中的图像 1,1
    • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
  4. Sony Vaio SVE171C11L Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Pull the battery away.
  5. Sony Vaio SVE171C11L Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two screws that secure the hard drive cover.
  6. Sony Vaio SVE171C11L Hard Drive Replacement: 步骤 6 中的图像 1,2 Sony Vaio SVE171C11L Hard Drive Replacement: 步骤 6 中的图像 2,2
    • After the screw have been removed, pop the hard drive cover open.
  7. Sony Vaio SVE171C11L Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 3 screws that secure the hard drive.
  8. Sony Vaio SVE171C11L Hard Drive Replacement: 步骤 8 中的图像 1,1
    • When finished removing the screws, use your fingers to hold the blue ribbon attached from the hard drive to remove it from laptop
结论
Edward Briseno
于09/26/22注册
896 声望
创作了6篇指南
团队
CSU Los Angeles, Team 6-3, Adachi Fall 2022 CSU Los Angeles, Team 6-3, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S6G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 19
总计 256
