跳转到主内容
Sony Vaio SVE151G11L Webcam Replacement
你所需要的
  1. Sony Vaio SVE151G11L Webcam Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE151G11L Webcam Replacement: 步骤 2 中的图像 1,1
    • Standing so that the barcode and warning labels are upright and legible, push the left tab up and away from yourself.
  3. Sony Vaio SVE151G11L Webcam Replacement: 步骤 3 中的图像 1,1
    • Standing so that the barcode and warning labels are upright and legible, push the right tab up and away from yourself.
  4. Sony Vaio SVE151G11L Webcam Replacement: 步骤 4 中的图像 1,1
    • Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
  5. Sony Vaio SVE151G11L Webcam Replacement: 步骤 5 中的图像 1,1
    • Pull battery away from laptop.
  6. Sony Vaio SVE151G11L Webcam Replacement, Display: 步骤 6 中的图像 1,1
    • Flip laptop over so the bottom is facing upwards.
    • Remove bottom of laptop.
  7. Sony Vaio SVE151G11L Webcam Replacement: 步骤 7 中的图像 1,1
    • Remove antenna wires attached to the WiFi card using a plastic opening tool.
  8. Sony Vaio SVE151G11L Webcam Replacement: 步骤 8 中的图像 1,1
    • Remove the other antenna wire.
  9. Sony Vaio SVE151G11L Webcam Replacement: 步骤 9 中的图像 1,1
    • Remove the display cable by pulling upwards.
  10. Sony Vaio SVE151G11L Webcam Replacement: 步骤 10 中的图像 1,1
    • Remove the power display cable with a plastic opening tool by pushing outwards.
  11. Sony Vaio SVE151G11L Webcam Replacement: 步骤 11 中的图像 1,2 Sony Vaio SVE151G11L Webcam Replacement: 步骤 11 中的图像 2,2
    • Remove 4 hinge screws with a Phillips #0 screwdriver.
  12. Sony Vaio SVE151G11L Webcam Replacement: 步骤 12 中的图像 1,2 Sony Vaio SVE151G11L Webcam Replacement: 步骤 12 中的图像 2,2
    • Lift upward on the hinges with a plastic opening tool to release them.
  13. Sony Vaio SVE151G11L Webcam Replacement: 步骤 13 中的图像 1,1
    • Separate the bottom of the laptop from the monitor.
  14. Sony Vaio SVE151G11L Webcam Replacement: 步骤 14 中的图像 1,1
    • Completely detach screen from the laptop.
  15. Sony Vaio SVE151G11L Webcam Replacement, Webcam: 步骤 15 中的图像 1,1
    • Remove the rubber nipples to expose the screws using the pointed side of the spudger.
  16. Sony Vaio SVE151G11L Webcam Replacement: 步骤 16 中的图像 1,1
    • Remove each of the screws revealed from the step below with a P00 screwdriver.
  17. Sony Vaio SVE151G11L Webcam Replacement: 步骤 17 中的图像 1,2 Sony Vaio SVE151G11L Webcam Replacement: 步骤 17 中的图像 2,2
    • Pop open display housing and follow the plastic to remove the screen.
  18. Sony Vaio SVE151G11L Webcam Replacement: 步骤 18 中的图像 1,2 Sony Vaio SVE151G11L Webcam Replacement: 步骤 18 中的图像 2,2
    • Remove the camera cable with the spudger.
  19. Sony Vaio SVE151G11L Webcam Replacement: 步骤 19 中的图像 1,1
    • Remove screws on both sides using a P000 screwdriver.
  20. Sony Vaio SVE151G11L Webcam Replacement: 步骤 20 中的图像 1,1
    • Pop out the board using a spudger.
  21. Sony Vaio SVE151G11L Webcam Replacement: 步骤 21 中的图像 1,1
    • The board is now removed.
结论
Azka Khanani
于10/17/18注册
313 声望
创作了2篇指南
团队
UMass Dartmouth, Team S9-G9, Valliere Fall 2018 UMass Dartmouth, Team S9-G9, Valliere Fall 2018 的会员
UMASSD-VALLIERE-F18S9G9
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 14
总计 1,052
