跳转到主内容
Sony Vaio SVE151G11L Speaker Replacement
你所需要的
  1. Sony Vaio SVE151G11L Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE151G11L Speaker Replacement: 步骤 2 中的图像 1,1
    • Standing so that the barcode and warning labels are upright and legible, push the left tab up and away from yourself.
  3. Sony Vaio SVE151G11L Speaker Replacement: 步骤 3 中的图像 1,1
    • Standing so that the barcode and warning labels are upright and legible, push the right tab up and away from yourself.
  4. Sony Vaio SVE151G11L Speaker Replacement: 步骤 4 中的图像 1,1
    • Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
  5. Sony Vaio SVE151G11L Speaker Replacement: 步骤 5 中的图像 1,1
    • Pull battery away from laptop.
  6. Sony Vaio SVE151G11L Speaker Replacement, Hard Disk Drive: 步骤 6 中的图像 1,1
    • Flip laptop over so the bottom is facing upwards.
  7. Sony Vaio SVE151G11L Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
  8. Sony Vaio SVE151G11L Speaker Replacement: 步骤 8 中的图像 1,2 Sony Vaio SVE151G11L Speaker Replacement: 步骤 8 中的图像 2,2
    • Pop open the cover to the HDD.
  9. Sony Vaio SVE151G11L Speaker Replacement: 步骤 9 中的图像 1,1
    • Remove the screws on the HDD with a Phillips #000 screwdriver.
  10. Sony Vaio SVE151G11L Speaker Replacement: 步骤 10 中的图像 1,2 Sony Vaio SVE151G11L Speaker Replacement: 步骤 10 中的图像 2,2
    • Pull plastic tab away from the laptop.
    • Lift HDD away from laptop.
  11. Sony Vaio SVE151G11L Speaker Replacement, Speakers: 步骤 11 中的图像 1,3 Sony Vaio SVE151G11L Speaker Replacement, Speakers: 步骤 11 中的图像 2,3 Sony Vaio SVE151G11L Speaker Replacement, Speakers: 步骤 11 中的图像 3,3
    • Remove the back cover.
  12. Sony Vaio SVE151G11L Speaker Replacement: 步骤 12 中的图像 1,2 Sony Vaio SVE151G11L Speaker Replacement: 步骤 12 中的图像 2,2
    • Remove 4 hinge screws with a Phillips #0 screwdriver.
  13. Sony Vaio SVE151G11L Speaker Replacement: 步骤 13 中的图像 1,3 Sony Vaio SVE151G11L Speaker Replacement: 步骤 13 中的图像 2,3 Sony Vaio SVE151G11L Speaker Replacement: 步骤 13 中的图像 3,3
    • Pop open hinge.
    • Remove black screw size P000.
  14. Sony Vaio SVE151G11L Speaker Replacement: 步骤 14 中的图像 1,2 Sony Vaio SVE151G11L Speaker Replacement: 步骤 14 中的图像 2,2
    • Remove wiring along its guide.
  15. Sony Vaio SVE151G11L Speaker Replacement: 步骤 15 中的图像 1,3 Sony Vaio SVE151G11L Speaker Replacement: 步骤 15 中的图像 2,3 Sony Vaio SVE151G11L Speaker Replacement: 步骤 15 中的图像 3,3
    • Remove two hinge screws size P00.
    • Pop open hinge.
  16. Sony Vaio SVE151G11L Speaker Replacement: 步骤 16 中的图像 1,2 Sony Vaio SVE151G11L Speaker Replacement: 步骤 16 中的图像 2,2
    • Remove black screw.
  17. Sony Vaio SVE151G11L Speaker Replacement: 步骤 17 中的图像 1,2 Sony Vaio SVE151G11L Speaker Replacement: 步骤 17 中的图像 2,2
    • Remove secondary black screw.
  18. Sony Vaio SVE151G11L Speaker Replacement: 步骤 18 中的图像 1,1
    • Remove speaker.
  19. Sony Vaio SVE151G11L Speaker Replacement: 步骤 19 中的图像 1,2 Sony Vaio SVE151G11L Speaker Replacement: 步骤 19 中的图像 2,2
    • Follow wire down its wire channel and remove it from the channel.
    • Pull up on the connector to disconnect the speakers to the motherboard.
  20. Sony Vaio SVE151G11L Speaker Replacement: 步骤 20 中的图像 1,1
    • Remove speaker and wire from the laptop.
结论
另外一个人完成了本指南。
Alex Theg
于10/15/18注册
758 声望
创作了4篇指南
团队
UMass Dartmouth, Team S9-G9, Valliere Fall 2018 UMass Dartmouth, Team S9-G9, Valliere Fall 2018 的会员
UMASSD-VALLIERE-F18S9G9
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 14
总计 405
