跳转到主内容
Sony Vaio SVE151G11L Motherboard Replacement
你所需要的
  1. Sony Vaio SVE151G11L Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE151G11L Motherboard Replacement: 步骤 2 中的图像 1,1
    • Standing so that the barcode and warning labels are upright and legible, push the left tab up and away from yourself.
  3. Sony Vaio SVE151G11L Motherboard Replacement: 步骤 3 中的图像 1,1
    • Standing so that the barcode and warning labels are upright and legible, push the right tab up and away from yourself.
  4. Sony Vaio SVE151G11L Motherboard Replacement: 步骤 4 中的图像 1,1
    • Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
  5. Sony Vaio SVE151G11L Motherboard Replacement: 步骤 5 中的图像 1,1
    • Pull battery away from laptop.
  6. Sony Vaio SVE151G11L Motherboard Replacement, Hard Disk Drive: 步骤 6 中的图像 1,1
    • Flip laptop over so the bottom is facing upwards.
  7. Sony Vaio SVE151G11L Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
  8. Sony Vaio SVE151G11L Motherboard Replacement: 步骤 8 中的图像 1,2 Sony Vaio SVE151G11L Motherboard Replacement: 步骤 8 中的图像 2,2
    • Pop open the cover to the HDD.
  9. Sony Vaio SVE151G11L Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the screws on the HDD with a Phillips #000 screwdriver.
  10. Sony Vaio SVE151G11L Motherboard Replacement: 步骤 10 中的图像 1,2 Sony Vaio SVE151G11L Motherboard Replacement: 步骤 10 中的图像 2,2
    • Pull plastic tab away from the laptop.
    • Lift HDD away from laptop.
  11. Sony Vaio SVE151G11L Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,1
    • Flip the laptop over on its backside.
  12. Sony Vaio SVE151G11L Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the screws holding the motherboard in place.
  13. Sony Vaio SVE151G11L Motherboard Replacement: 步骤 13 中的图像 1,2 Sony Vaio SVE151G11L Motherboard Replacement: 步骤 13 中的图像 2,2
    • Pop the motherboard away from the frame.
  14. Sony Vaio SVE151G11L Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove the ribbon cable from the motherboard.
  15. Sony Vaio SVE151G11L Motherboard Replacement: 步骤 15 中的图像 1,2 Sony Vaio SVE151G11L Motherboard Replacement: 步骤 15 中的图像 2,2
    • Remove motherboard from the laptop.
结论
2等其他人完成本指南。
Alex Theg
于10/15/18注册
758 声望
创作了4篇指南
团队
UMass Dartmouth, Team S9-G9, Valliere Fall 2018 UMass Dartmouth, Team S9-G9, Valliere Fall 2018 的会员
UMASSD-VALLIERE-F18S9G9
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 1,773
