跳转到主内容
Sony Vaio SVE15112FXS Speaker Replacement
你所需要的
  1. Sony Vaio SVE15112FXS Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 2 中的图像 1,1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 3 中的图像 1,2 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 3 中的图像 2,2
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 4 中的图像 1,1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 5 中的图像 1,2 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 5 中的图像 2,2
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the one 4.0 mm screw next to the model number label.
  7. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 7 中的图像 1,1
    • Use a plastic opening tool to slide the CD-ROM out from the laptop.
  8. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 8 中的图像 1,3 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 8 中的图像 2,3 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 8 中的图像 3,3
    • Slide the "lock" tab upward to unlock the battery before removal.
    • While pushing the "release" tab upward, lift the battery and pull outward to remove it from the laptop.
  9. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 9 中的图像 1,3 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 9 中的图像 2,3 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 9 中的图像 3,3
    • To unsecure the bottom cover, remove all the cover screws using a #0 Phillips screwdriver.
    • Remove the two 9.0 mm screws on each side of the battery.
    • Remove the twelve 8.0 mm long screws alongside the entire back cover.
    • Remove the three 3.0 mm screws inside the battery well.
  10. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 10 中的图像 1,3 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 10 中的图像 2,3 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 10 中的图像 3,3
    • Use a plastic opening tool to carefully pry open the latch points located under the silver plastic trim. Repeat this around the back cover.
    • It may be easiest to start around the CD-ROM bay because there is more room.
    • To avoid damaging the plastic trim and cover, do not force difficult areas and make sure the opening tool is completely under the black plastic cover, not just the silver trim.
    • Lift the back cover upward and away from the laptop.
  11. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 11 中的图像 1,1
    • Rotate the laptop so that the battery well is closest to you and the fan unit is on the left side.
  12. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 12 中的图像 1,2 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 12 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the two 9.0 mm lid hinge screws next to the left and right speaker unit.
  13. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 13 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the one 3.0 mm screw attaching the grounding wire to the left lid hinge.
  14. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 14 中的图像 1,3 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 14 中的图像 2,3 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 14 中的图像 3,3
    • Use a metal spudger to pry upward and loosen the lid hinge next to the left and right speaker unit.
    • Pull each lid hinge toward you until they are completely out of the way.
  15. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 15 中的图像 1,2 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 15 中的图像 2,2
    • Use a plastic opening tool to unsecure the white charging connector above the left speaker unit.
    • Do not pull on the wires as this could rip them from the charging connector.
  16. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 16 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the one 4.0 mm screw attaching the grounding wire to the large screen cable.
    • This allows you to move the screen cable to access the speaker screw underneath it. Do not disconnect the screen cable itself.
    • Look for a white arrow on the motherboard if you are having trouble identifying this screw.
  17. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 17 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the two 3.0 mm screws securing the left and right speaker unit to the laptop.
  18. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 18 中的图像 1,3 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 18 中的图像 2,3 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 18 中的图像 3,3
    • Start with the left speaker and carefully guide the unit while unwrapping the black and white wires from the wire guides.
    • Repeat this process with the right speaker unit. These wires will be black and red.
    • Take note of how the wires are wrapped around the hooks.
  19. Sony Vaio SVE15112FXS Speaker Replacement: 步骤 19 中的图像 1,2 Sony Vaio SVE15112FXS Speaker Replacement: 步骤 19 中的图像 2,2
    • Use a plastic opening tool to unsecure the white speaker wire connector on the motherboard.
    • Do not pull on the wires as this could rip them from the connector.
结论
另外一个人完成了本指南。
Ashley Bierman
于09/06/18注册
1,223 声望
创作了5篇指南
团队
Ohio State, Team S1-G1, Whitney Fall 2018 Ohio State, Team S1-G1, Whitney Fall 2018 的会员
OSU-WHITNEY-F18S1G1
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 24
总计 2,262
