跳转到主内容
Sony Vaio SVE15112FXS LCD Screen Replacement
你所需要的
  1. Sony Vaio SVE15112FXS LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 2 中的图像 1,3 Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 2 中的图像 2,3 Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Slide the "lock" tab upward to unlock the battery before removal.
    • While pushing the "release" tab upward, lift the battery and pull outward to remove it from the laptop.
  3. Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Turn the computer back over and open the lid.
    • Remove the four rubber screw covers at each corner of the screen to expose the bezel screws
  4. Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screen bezel screws in each corner.
  5. Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 5 中的图像 1,2 Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Insert a plastic opening tool between the bezel and laptop lid. Work it around the edge to loosen the bezel.
    • Lift the bezel outward to remove it and expose the screen.
    • Take care when using the spudger near the hinges to avoid breaking the bezel.
  6. Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 6 中的图像 1,2 Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Use a #0 Phillips screwdriver to remove the four 3.0 mm screen screws.
    • Cover the keyboard with a cloth or towel to protect the screen and keep any broken glass out of the keyboard.
  7. Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 7 中的图像 1,3 Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 7 中的图像 2,3 Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Pull the screen toward you and away from the lid until a silver cable behind the screen is visible.
    • Remove the silver cable from the back of the screen. It is glued at the top and the bottom.
    • Do not pull the cable loose from the lid, only remove it from the back of the screen.
  8. Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 8 中的图像 1,3 Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 8 中的图像 2,3 Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Lift the barcode label on the back of the screen upward to loosen the screen cable connector.
    • Once the connector is visible, remove it from the pins on the back of the screen.
  9. Sony Vaio SVE15112FXS LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Lift the screen toward you to remove it completely from the lid.
结论
另外一个人完成了本指南。
Ashley Bierman
于09/06/18注册
1,301 声望
创作了5篇指南
团队
Ohio State, Team S1-G1, Whitney Fall 2018 Ohio State, Team S1-G1, Whitney Fall 2018 的会员
OSU-WHITNEY-F18S1G1
2 名成员
创作了11篇指南
1指南评论
How to buy the screen.my screen has gone...
PCG21212w 19.5V Sony vaio - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 33
总计 1,219
