跳转到主内容
Sony Vaio SVE15112FXS Hard Drive Replacement
你所需要的
  1. Sony Vaio SVE15112FXS Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Hard Drive Replacement: 步骤 3 中的图像 1,2 Sony Vaio SVE15112FXS Hard Drive Replacement: 步骤 3 中的图像 2,2
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Hard Drive Replacement: 步骤 5 中的图像 1,2 Sony Vaio SVE15112FXS Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Hard Drive Replacement: 步骤 6 中的图像 1,2 Sony Vaio SVE15112FXS Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screws attaching the mount to the hard drive.
    • Slide the hard drive away from the mount until it is completely detached.
    • Take note of how the mount is positioned when attached to the hard drive.
结论
另外一个人完成了本指南。
Ashley Bierman
于09/06/18注册
1,223 声望
创作了5篇指南
团队
Ohio State, Team S1-G1, Whitney Fall 2018 Ohio State, Team S1-G1, Whitney Fall 2018 的会员
OSU-WHITNEY-F18S1G1
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 708
