跳转到主内容
Sony Vaio SVE111B11L Keyboard Assembly Replacement
你所需要的
  1. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Battery: 步骤 1 中的图像 1,2 Sony Vaio SVE111B11L Keyboard Assembly Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Keyboard Assembly Replacement: 步骤 2 中的图像 1,1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Keyboard Assembly Replacement: 步骤 3 中的图像 1,1
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Keyboard Assembly: 步骤 4 中的图像 1,1
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L Keyboard Assembly Replacement: 步骤 5 中的图像 1,1
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L Keyboard Assembly Replacement: 步骤 6 中的图像 1,1
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L Keyboard Assembly Replacement: 步骤 7 中的图像 1,3 Sony Vaio SVE111B11L Keyboard Assembly Replacement: 步骤 7 中的图像 2,3 Sony Vaio SVE111B11L Keyboard Assembly Replacement: 步骤 7 中的图像 3,3
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 1,212
