跳转到主内容
Sony Vaio SVE111B11L Screen Replacement
你所需要的
  1. Sony Vaio SVE111B11L  Screen Replacement, Battery: 步骤 1 中的图像 1,2 Sony Vaio SVE111B11L  Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L  Screen Replacement: 步骤 2 中的图像 1,1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L  Screen Replacement: 步骤 3 中的图像 1,1
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L  Screen Replacement, Keyboard Assembly: 步骤 4 中的图像 1,1
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L  Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L  Screen Replacement: 步骤 6 中的图像 1,1
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L  Screen Replacement: 步骤 7 中的图像 1,3 Sony Vaio SVE111B11L  Screen Replacement: 步骤 7 中的图像 2,3 Sony Vaio SVE111B11L  Screen Replacement: 步骤 7 中的图像 3,3
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
  8. Sony Vaio SVE111B11L  Screen Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Remove charging adaptor. Some charge may still be in the battery or computer.
    • DO NOT touch connectors or copper yellow connector.
    • Take the covers on the bottom of the laptop off.
  9. Sony Vaio SVE111B11L  Screen Replacement: 步骤 9 中的图像 1,1
    • Locate and remove the screws holding the motherboard down.
    • Screws: L 4.6mm X D 1.85mm
  10. Sony Vaio SVE111B11L  Screen Replacement: 步骤 10 中的图像 1,3 Sony Vaio SVE111B11L  Screen Replacement: 步骤 10 中的图像 2,3 Sony Vaio SVE111B11L  Screen Replacement: 步骤 10 中的图像 3,3
    • Locate the wires and connectors and remove them from the motherboard.
  11. Sony Vaio SVE111B11L  Screen Replacement: 步骤 11 中的图像 1,2 Sony Vaio SVE111B11L  Screen Replacement: 步骤 11 中的图像 2,2
    • Lift the mother board out and safely put it to the side.
  12. Sony Vaio SVE111B11L  Screen Replacement, Screen: 步骤 12 中的图像 1,2 Sony Vaio SVE111B11L  Screen Replacement, Screen: 步骤 12 中的图像 2,2
    • Remove charging adaptor and battery. Some charge may still be in the battery or computer.
    • Locate screws. L 3.35mm X D 1.8mm
    • Remove Screws.
    • Lay the screen on a hard flat surface.
    • Remove hinges and wires for ease of removal.
  13. Sony Vaio SVE111B11L  Screen Replacement: 步骤 13 中的图像 1,1
    • Gently remove the screen cover.
    • Be careful of the camera at the top of the screen.
    • Be careful of the seal tape between the cover and the screen.
  14. Sony Vaio SVE111B11L  Screen Replacement: 步骤 14 中的图像 1,3 Sony Vaio SVE111B11L  Screen Replacement: 步骤 14 中的图像 2,3 Sony Vaio SVE111B11L  Screen Replacement: 步骤 14 中的图像 3,3
    • Locate the wires and connectors.
    • Unplug the wires from the connectors.
    • Be careful of the yellow tape around the connection.
  15. Sony Vaio SVE111B11L  Screen Replacement: 步骤 15 中的图像 1,2 Sony Vaio SVE111B11L  Screen Replacement: 步骤 15 中的图像 2,2
    • Gently lift the screen assembly up and out.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 12
总计 1,235
