跳转到主内容
加入维修社区 - 创建账户
Sony Vaio Pro 13 Solid State Drive Replacement
你所需要的
  1. Sony Vaio Pro 13 Solid State Drive Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Sony Vaio Pro 13 Solid State Drive Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
    • Remove the two rubber feet at the back of the computer, these can be removed in the same way.
    询问修复机器人
  2. Sony Vaio Pro 13 Solid State Drive Replacement: 步骤 2 中的图像 1,2 Sony Vaio Pro 13 Solid State Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the four 5.6mm Philips #00 screws located at the top of the computer.
    • Remove the eight 3.6mm Philips #00 screws on the base of the computer.
    询问修复机器人
  3. Sony Vaio Pro 13 Solid State Drive Replacement: 步骤 3 中的图像 1,2 Sony Vaio Pro 13 Solid State Drive Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands.
    • Leave the side with the USB and audio port until last, then slide the case out and off, so the audio port doesn't get caught.
    询问修复机器人
  4. Sony Vaio Pro 13 Solid State Drive Replacement, Solid State Drive: 步骤 4 中的图像 1,3 Sony Vaio Pro 13 Solid State Drive Replacement, Solid State Drive: 步骤 4 中的图像 2,3 Sony Vaio Pro 13 Solid State Drive Replacement, Solid State Drive: 步骤 4 中的图像 3,3
    • Remove the 4mm #0 Philips screw holding down the SSD
    • Lift the SSD up and slide out of the slot
    询问修复机器人
结论
10等其他人完成本指南。
4指南评论
My internal hard drive does not get detected sometimes. I had this same problem a few months back. Upon getting it repaired by computer technician, I was told the issue was in the hard drive cover which connects the SSD to the PC. The issue got fixed at a cost of $100. I am not sure what that meant but the same issue has returned.
I don't believe I have to replace my solid state drive. Can anyone offer me any solutions?
Sagar Taurani - 回复 分享
Hello Sagar, I have the same issue, did you get it fixed eventually?
Thanks! Olivier
Olivier Guerreau - 回复 分享
I have the same issue. Once I replace the SSD - the new one is not recognized on boot. If I boot an external OS, I can access the SSD - so it seems to work but for some reason the BIOS does not see it on boot up.
Any ideas/solutions out there?
Mad Sony - 回复 分享
Yes, if this one slot stick on Sony 13Pro, it needs to be ahci-pcie, not nvme. NVME does not boot without editing bios code.
vesa.kuusava - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 65
总计 16,754
