跳转到主内容
Sony Vaio Pro 13 Bottom Cover Replacement
你所需要的
  1. Sony Vaio Pro 13 Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Sony Vaio Pro 13 Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
    • Remove the two rubber feet at the back of the computer, these can be removed in the same way.
  2. Sony Vaio Pro 13 Bottom Cover Replacement: 步骤 2 中的图像 1,2 Sony Vaio Pro 13 Bottom Cover Replacement: 步骤 2 中的图像 2,2
    • Remove the four 5.6mm Philips #00 screws located at the top of the computer.
    • Remove the eight 3.6mm Philips #00 screws on the base of the computer.
  3. Sony Vaio Pro 13 Bottom Cover Replacement: 步骤 3 中的图像 1,2 Sony Vaio Pro 13 Bottom Cover Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands.
    • Leave the side with the USB and audio port until last, then slide the case out and off, so the audio port doesn't get caught.
结论
7等其他人完成本指南。
一条评论
Hi…I have same laptop, what your advice getting the cover back on? especially near the audio and usb ports…that my hang up
thanks
chrisrai - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 6,955
