跳转到主内容
加入维修社区 - 创建账户
Sony Vaio PCG-F420 RAM Replacement
你所需要的
    1. Sony Vaio PCG-F420 RAM Replacement, Battery: 步骤 1 中的图像 1,1
      • The battery is located on the left side of the laptop, as shown by the red circle.
      • Make sure the laptop is disconnected and turned completely off.
      询问修复机器人
      添加评论
    2. Sony Vaio PCG-F420 RAM Replacement: 步骤 2 中的图像 1,1
      • Remove the battery by following these steps.
      • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
      • The battery can now be removed by pulling it.
      询问修复机器人
      添加评论
    1. Sony Vaio PCG-F420 RAM Replacement, RAM: 步骤 3 中的图像 1,1
      • Remove the screw holding the RAM cover down.
      询问修复机器人
      添加评论
    2. Sony Vaio PCG-F420 RAM Replacement: 步骤 4 中的图像 1,1
      • Use a spudger to lift the covering, revealing the RAM modules inside the computer.
      询问修复机器人
      添加评论
    3. Sony Vaio PCG-F420 RAM Replacement: 步骤 5 中的图像 1,1
      • To remove the RAM currently inside the computer, gently pull out the white tabs on each side of the RAM module.
      • The RAM will pop up at an angle where it can be pulled out without damaging the socket.
      • Remove the RAM module by pulling at the same angle the RAM is at.
      询问修复机器人
      添加评论
    4. Sony Vaio PCG-F420 RAM Replacement: 步骤 6 中的图像 1,1
      • To insert the new RAM module, match the notch in the middle of the gold edge of the RAM to the notch in the laptop.
      • Insert the RAM at the same angle the other module came out at and make sure the end of the ram is actually in the slot. Gently push down on the RAM until it clicks in.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 29-77, Johann Spring 2010 Cal Poly, Team 29-77, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G77
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 35
总计 2,763
