跳转到主内容
Sony Vaio PCG-F360 Optical Drive Replacement
你所需要的
  1. Sony Vaio PCG-F360 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: 步骤 5 中的图像 1,3 Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: 步骤 5 中的图像 2,3 Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: 步骤 5 中的图像 3,3
    • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 6 中的图像 1,3 Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 6 中的图像 2,3 Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 6 中的图像 3,3
    • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 7 中的图像 1,2 Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 7 中的图像 2,2
    • Remove the metal screw that will be located at the red circle.
    • Pull on the green strip, and the keyboard should come free easily.
  8. Sony Vaio PCG-F360 Optical Drive Replacement, Optical Drive: 步骤 8 中的图像 1,2 Sony Vaio PCG-F360 Optical Drive Replacement, Optical Drive: 步骤 8 中的图像 2,2
    • Remove the three screws surrounding the fan.
    • Take off the guard that you just unscrewed.
    • Carefully flip over the heat pipe and the metal sheet connected to it.
  9. Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 9 中的图像 1,3 Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 9 中的图像 2,3 Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 9 中的图像 3,3
    • Remove the three screws from the heat tube cover.
    • Carefully remove the cover.
  10. Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 10 中的图像 1,2 Sony Vaio PCG-F360 Optical Drive Replacement: 步骤 10 中的图像 2,2
    • Use a spudger to pry the ribbon connected to the optical drive.
    • Slide the optical drive free of the enclosure.
结论
ahintz
于04/21/10注册
28 声望
创作了8篇指南
团队
Cal Poly, Team 16-3, Maness Spring 2010 Cal Poly, Team 16-3, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 1,771
