跳转到主内容
加入维修社区 - 创建账户
Sony Vaio PCG-F360 Keyboard Replacement
你所需要的
  1. Sony Vaio PCG-F360 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Keyboard Replacement: 步骤 4 中的图像 1,1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,3 Sony Vaio PCG-F360 Keyboard Replacement, Keyboard: 步骤 5 中的图像 2,3 Sony Vaio PCG-F360 Keyboard Replacement, Keyboard: 步骤 5 中的图像 3,3
    • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony Vaio PCG-F360 Keyboard Replacement: 步骤 6 中的图像 1,3 Sony Vaio PCG-F360 Keyboard Replacement: 步骤 6 中的图像 2,3 Sony Vaio PCG-F360 Keyboard Replacement: 步骤 6 中的图像 3,3
    • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony Vaio PCG-F360 Keyboard Replacement: 步骤 7 中的图像 1,2 Sony Vaio PCG-F360 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Remove the metal screw that will be located at the red circle.
    • Pull on the green strip, and the keyboard should come free easily.
结论
ahintz
于04/21/10注册
28 声望
创作了8篇指南
团队
Cal Poly, Team 16-3, Maness Spring 2010 Cal Poly, Team 16-3, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G3
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 55
总计 1,545
