跳转到主内容
Sony Vaio PCG-F360 Battery Replacement
  1. Sony Vaio PCG-F360 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Battery Replacement: 步骤 2 中的图像 1,1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Battery Replacement: 步骤 3 中的图像 1,1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Battery Replacement: 步骤 4 中的图像 1,1
    • The battery is now removed and it is safe to move on to uninstalling other components.
结论
另外一个人完成了本指南。
ahintz
于04/21/10注册
28 声望
创作了8篇指南
团队
Cal Poly, Team 16-3, Maness Spring 2010 Cal Poly, Team 16-3, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,785
