跳转到主内容
Replacing the Sony Vaio PCG-981L DVD drive
你所需要的
  1. Replacing the Sony Vaio PCG-981L DVD drive, DVD drive: 步骤 1 中的图像 1,3 Replacing the Sony Vaio PCG-981L DVD drive, DVD drive: 步骤 1 中的图像 2,3 Replacing the Sony Vaio PCG-981L DVD drive, DVD drive: 步骤 1 中的图像 3,3
    • The parts of the laptop that will be referenced throughout this guide follow.
    • The power panel is shown in the first photo.
    • The power panel ribbon is located on the back of the power panel. This is the white ribbon in the second photo.
    • The keyboard and keyboard ribbon are located within the red box highlighted in the third photo.
  2. Replacing the Sony Vaio PCG-981L DVD drive: 步骤 2 中的图像 1,3 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 2 中的图像 2,3 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 2 中的图像 3,3
    • Keep laptop sitting on table to avoid dropping it and causing irreparable damage.
    • Open the laptop.
    • Using a Phillips screwdriver, remove the power panel screw located on the left side of the laptop. See the red box in the photo for the location of the screw.
    • Remove the power panel by sliding it to the right and gently lifting it upwards.
    • Gently detach the power panel ribbon from the motherboard by sliding the ribbon out of the plastic connector, meanwhile keeping it attached to the power panel.
  3. Replacing the Sony Vaio PCG-981L DVD drive: 步骤 3 中的图像 1,3 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 3 中的图像 2,3 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 3 中的图像 3,3
    • Detach the keyboard ribbon cable from the motherboard.
    • Lift the top latch of the plastic connection piece. Once the latch is lifted, pull the ribbon cable out and slide the keyboard out.
    • Photo three shows the DVD drive once the power panel and keyboard tray have been removed.
  4. Replacing the Sony Vaio PCG-981L DVD drive: 步骤 4 中的图像 1,3 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 4 中的图像 2,3 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 4 中的图像 3,3
    • Remove the first screw from the DVD drive with a Phillips screwdriver. Refer to the first photo for the location of the screw.
    • Remove the second screw from the DVD drive with a Phillips screwdriver. Refer to the second photo for the location of the screw.
  5. Replacing the Sony Vaio PCG-981L DVD drive: 步骤 5 中的图像 1,3 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 5 中的图像 2,3 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 5 中的图像 3,3
    • Gently detach the ribbon cable from the DVD drive. Pull the hard part of the cable straight back from the DVD drive.
    • Remove the DVD drive from the laptop by gently sliding it out through the outside of the laptop.
  6. Replacing the Sony Vaio PCG-981L DVD drive: 步骤 6 中的图像 1,2 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 6 中的图像 2,2
    • Congratulations! You have just successfully removed the DVD drive. You are now ready to install new DVD drive.
  7. Replacing the Sony Vaio PCG-981L DVD drive: 步骤 7 中的图像 1,3 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 7 中的图像 2,3 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 7 中的图像 3,3
    • Gently slide the DVD drive into the laptop. If the drive gets stuck while sliding in, gently push down on the metal bay below the DVD drive to allow the DVD drive to slide over.
    • Reattach the ribbon cable to the DVD drive.
    • Replace both of the DVD drive screws. See the third photo for reference.
  8. Replacing the Sony Vaio PCG-981L DVD drive: 步骤 8 中的图像 1,3 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 8 中的图像 2,3 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 8 中的图像 3,3
    • Reattach the keyboard ribbon cable to the motherboard by sliding the ribbon cable into the plastic connector and then pushing top down to latch it, then sliding the keyboard back into place.
    • Reattach the power panel ribbon cable to the motherboard, then slide the power panel into place.
  9. Replacing the Sony Vaio PCG-981L DVD drive: 步骤 9 中的图像 1,2 Replacing the Sony Vaio PCG-981L DVD drive: 步骤 9 中的图像 2,2
    • Replace power panel side screw.
    • Congratulations! The installation is now complete!
终点
Genaro Sanchez
于04/14/10注册
46 声望
创作了2篇指南
团队
Cal Poly, Team 18-68, Johann Spring 2010 Cal Poly, Team 18-68, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G68
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 5,153
