跳转到主内容
Sony Vaio PCG-981L Clock battery Replacement
你所需要的
  1. Sony Vaio PCG-981L Clock battery Replacement, Clock Battery: 步骤 1 中的图像 1,1
    • Place the computer on a flat surface.
  2. Sony Vaio PCG-981L Clock battery Replacement: 步骤 2 中的图像 1,2 Sony Vaio PCG-981L Clock battery Replacement: 步骤 2 中的图像 2,2
    • Flip your computer upside down.
    • Use a Phillips #1 screwdriver to remove the single screw securing the cover.
  3. Sony Vaio PCG-981L Clock battery Replacement: 步骤 3 中的图像 1,1
    • Remove the capsule cover to reveal the computer chip.
  4. Sony Vaio PCG-981L Clock battery Replacement: 步骤 4 中的图像 1,1
    • After removing the cover, identify the two screws holding the computer chip in place.
    • Use a Phillips #1 screwdriver to remove the two screws that secure the computer chip by turning your screwdriver counterclockwise.
  5. Sony Vaio PCG-981L Clock battery Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the computer chip and set it aside.
  6. Sony Vaio PCG-981L Clock battery Replacement: 步骤 6 中的图像 1,1
    • Using your thumb or index finger, locate the clock battery on the upper part of the capsule.
    • Apply pressure to the clock battery until it pops out and remove it from your computer.
  7. Sony Vaio PCG-981L Clock battery Replacement: 步骤 7 中的图像 1,1
    • Push your new clock battery into place using your thumb or index finger at the same place where you removed the old clock battery.
  8. Sony Vaio PCG-981L Clock battery Replacement: 步骤 8 中的图像 1,1
    • Carefully replace the computer chip and secure the two screws using your Phillips #1 screwdriver by turning the screwdriver clockwise.
  9. Sony Vaio PCG-981L Clock battery Replacement: 步骤 9 中的图像 1,1
    • Secure the capsule cover with the screw the same way.
  10. Sony Vaio PCG-981L Clock battery Replacement: 步骤 10 中的图像 1,1
    • Flip your computer right side up and turn it on to make sure everything is functioning properly.
结论
If your computer does not function properly after you have completed this guide, please review the guide to see if you missed a step. If not, contact your computer manufacturer for assistance.
团队
Cal Poly, Team 18-68, Johann Spring 2010 Cal Poly, Team 18-68, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G68
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 4,820
