跳转到主内容
Sony Vaio VGN-FS640 RAM Cover Replacement
你所需要的
  1. Sony Vaio VGN-FS640 RAM Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 RAM Cover Replacement: 步骤 2 中的图像 1,1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 RAM Cover Replacement: 步骤 3 中的图像 1,2 Sony Vaio VGN-FS640 RAM Cover Replacement: 步骤 3 中的图像 2,2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: 步骤 4 中的图像 1,2 Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: 步骤 4 中的图像 2,2
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
  5. Sony Vaio VGN-FS640 RAM Cover Replacement: 步骤 5 中的图像 1,3 Sony Vaio VGN-FS640 RAM Cover Replacement: 步骤 5 中的图像 2,3 Sony Vaio VGN-FS640 RAM Cover Replacement: 步骤 5 中的图像 3,3
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
结论
Brian Marchini
于04/15/10注册
293 声望
创作了2篇指南
团队
Cal Poly, Team 24-32, Regan Spring 2010 Cal Poly, Team 24-32, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G32
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 4,797
