简介
This guide gives instructions to remove a broken LCD screen from the Sony Vaio PCG-7A2L laptop and replace it with a new screen.
工具
配件
With the bottom of the laptop facing up, locate the RAM cover.
The RAM is covered by the panel with four columns of vents.
Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
Slide the cover until it is free from the laptop case.
Lift the cover to remove.
Locate the screws highlighted here. There are 16 total.
Using a Phillips #0 screwdriver, remove the screws (Length: 6.8mm) and place them on a tray for later use.
After the back cover is removed, lay the laptop on a flat surface, with the bottom facing up.
On each side of the white plastic connector, there is a tiny black tab that locks the ribbon into place.
Use the sharp edge of a spudger to slide the black tabs away from from the white plastic connector.
Once the tabs have been extended away from the connector, the ribbon can be removed from the keyboard.
The keyboard is now completely disconnected from the laptop.
At this point the speaker cover and keyboard should be removed and the laptop should be sitting in its normal open position with the screen facing you.
Once the new screen and its cables are securely in place, attach the three cables to their corresponding ports.
For each cable, place the connector on top of the port and align the two as close as possible.
To connect the power cable, use your finger to push downward on the middle of the connector until it snaps into place.
To connect each display cable, use the flat end of a spudger to press on the top of the silver connector until it snaps into place.
Your new LCD screen is now fully installed.
Work backwards through the Keyboard Removal Guide, to reconstruct the rest of the laptop.
4等其他人完成本指南。
