跳转到主内容
Sony Vaio VGN-FS640 Hard Drive Replacement
你所需要的
  1. Sony Vaio VGN-FS640 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 Hard Drive Replacement: 步骤 3 中的图像 1,2 Sony Vaio VGN-FS640 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,3 Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,3 Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 3,3
    • Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
    • Slide the cover until it is free from the laptop case.
    • Lift the cover to remove.
  5. Sony Vaio VGN-FS640 Hard Drive Replacement: 步骤 5 中的图像 1,3 Sony Vaio VGN-FS640 Hard Drive Replacement: 步骤 5 中的图像 2,3 Sony Vaio VGN-FS640 Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
    • Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
    • The Hard Drive should now be disconnected.
    • Lift the drive out with the tab on the tray.
结论
2等其他人完成本指南。
Matt McCarty
于04/15/10注册
220 声望
创作了2篇指南
团队
Cal Poly, Team 24-32, Regan Spring 2010 Cal Poly, Team 24-32, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G32
4 名成员
创作了16篇指南
一条评论
cant sign to recover my external hard drive
manivanan88 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 10,568
