本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide show you how to remove the back cover to access the CD-ROM drive, the cooling fan, and other parts in order to remove the keyboard and screen.
你所需要的
With the bottom of the laptop facing up, locate the RAM cover.
The RAM is covered by the panel with four columns of vents.
Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
Slide the cover until it is free from the laptop case.
Lift the cover to remove.
Locate the screws highlighted here. There are 16 total.
Using a Phillips #0 screwdriver, remove the screws (Length: 6.8mm) and place them on a tray for later use.
4等其他人完成本指南。
