跳转到主内容
Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement
  1. Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off the laptop.
    • Unplug the charging cable and any other cables plugged into the laptop.
    • Failure to remove or unplug any cables could result in electric shock.
    • Turn the laptop over so that the back panel is facing upwards.
  2. Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement: 步骤 2 中的图像 1,1
    • Locate two switches above the battery that lock it into place.
    • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
  3. Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement: 步骤 3 中的图像 1,1
    • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
结论
To reassemble your battery, line up the battery and slide it in until the second lock (left hand switch) clicks. Then lock the 1st switch.
4等其他人完成本指南。
Brian Luu
于04/08/14注册
720 声望
创作了3篇指南
团队
Cal Poly, Team 9-17, Regan Spring 2014 Cal Poly, Team 9-17, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G17
4 名成员
创作了18篇指南
一条评论
How to test my battery performance Sony VAIO
Pcg- 7184L
Ramesh C - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 3,254
