当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Set the computer display-side down.
Unlock the battery by sliding the port-side latch to the 'unlock' position.
On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
Unscrew the two memory panel screws and set the panel aside.
Ignore the removal of the heatsink panel. This does not need to be removed for RAM module access.
Lift the film covering to reveal the memory module with the tweezers.
Pull the tabs on both sides of the RAM away from the module. The module will pop up.
Repeat this step for the other RAM module located directly above the memory module just removed.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与8其他贡献者
于04/11/10注册
154 声望
创作了2篇指南
徽章: 9
+ 6更多徽章
CPSU-AMIDO-S10S25G89
4 名成员
创作了63篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 16
总计 4,959
