跳转到主内容
Sony Vaio VGN-SZ120P Memory Replacement
你所需要的
  1. Sony Vaio VGN-SZ120P Memory Replacement, Battery: 步骤 1 中的图像 1,1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Memory Replacement: 步骤 2 中的图像 1,1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Memory Replacement, Memory: 步骤 3 中的图像 1,2 Sony Vaio VGN-SZ120P Memory Replacement, Memory: 步骤 3 中的图像 2,2
    • Unscrew the two memory panel screws and set the panel aside.
    • Ignore the removal of the heatsink panel. This does not need to be removed for RAM module access.
  4. Sony Vaio VGN-SZ120P Memory Replacement: 步骤 4 中的图像 1,3 Sony Vaio VGN-SZ120P Memory Replacement: 步骤 4 中的图像 2,3 Sony Vaio VGN-SZ120P Memory Replacement: 步骤 4 中的图像 3,3
    • Lift the film covering to reveal the memory module with the tweezers.
    • Pull the tabs on both sides of the RAM away from the module. The module will pop up.
    • Repeat this step for the other RAM module located directly above the memory module just removed.
结论
另外一个人完成了本指南。
Ryan
于04/11/10注册
154 声望
创作了2篇指南
团队
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G89
4 名成员
创作了63篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 4,943
