当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
Remove the Torx security screw near the center of the battery-side edge.
The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
Remove the keyboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
