跳转到主内容
Sony Vaio PCG-61411L Optical Disc Drive Replacement
你所需要的
  1. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: 步骤 1 中的图像 1,3 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: 步骤 1 中的图像 2,3 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 2 中的图像 1,3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 2 中的图像 2,3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 2 中的图像 3,3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • The hard drive panel is located in the bottom right corner of the device.
  4. Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 4 中的图像 1,2 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 4 中的图像 2,2
    • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
    • Remove the panel by pulling it up towards yourself.
  5. Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 5 中的图像 1,3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 5 中的图像 2,3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 5 中的图像 3,3
    • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
    • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
    • Carefully remove the silver hard drive cover.
  6. Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 6 中的图像 1,3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 6 中的图像 2,3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 6 中的图像 3,3
    • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
  7. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Optical Disc Drive: 步骤 7 中的图像 1,2 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Optical Disc Drive: 步骤 7 中的图像 2,2
    • Remove the 5mm screws with the PH0 screwdriver.
    • Remove the 3mm screws with the PH0 screwdriver.
  8. Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 8 中的图像 1,2 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 8 中的图像 2,2
    • Lift the backplate from bottom right and left corner and remove it from the laptop.
  9. Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 9 中的图像 1,2 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 步骤 9 中的图像 2,2
    • Slide your finger from the right of the optical disc and pull the optical disc from right to left.
结论
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 591
