跳转到主内容
Sony Vaio PCG-61411L Hard Drive Replacement
你所需要的
  1. Sony Vaio PCG-61411L Hard Drive Replacement, Battery: 步骤 1 中的图像 1,3 Sony Vaio PCG-61411L Hard Drive Replacement, Battery: 步骤 1 中的图像 2,3 Sony Vaio PCG-61411L Hard Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L Hard Drive Replacement: 步骤 2 中的图像 1,3 Sony Vaio PCG-61411L Hard Drive Replacement: 步骤 2 中的图像 2,3 Sony Vaio PCG-61411L Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • The hard drive panel is located in the bottom right corner of the device.
  4. Sony Vaio PCG-61411L Hard Drive Replacement: 步骤 4 中的图像 1,2 Sony Vaio PCG-61411L Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
    • Remove the panel by pulling it up towards yourself.
  5. Sony Vaio PCG-61411L Hard Drive Replacement: 步骤 5 中的图像 1,3 Sony Vaio PCG-61411L Hard Drive Replacement: 步骤 5 中的图像 2,3 Sony Vaio PCG-61411L Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
    • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
    • Carefully remove the silver hard drive cover.
  6. Sony Vaio PCG-61411L Hard Drive Replacement: 步骤 6 中的图像 1,3 Sony Vaio PCG-61411L Hard Drive Replacement: 步骤 6 中的图像 2,3 Sony Vaio PCG-61411L Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
结论
另外一个人完成了本指南。
Sean Lyon
于03/01/18注册
381 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 1,587
