本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide demonstrates how to access the wifi card successfully in order to replace or repair the wifi card if necessary.
你所需要的
Now, remove the small covers from the back of the case.
Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
Then, lift up on and remove these covers as shown in the third image.
Using your fingers, grasp the white and black wires connected to the wifi card. Pull up on these wires until they release from the card. Do not be afraid to use some force.
