当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the four rubber circles using the spudger located on each corner of the laptop.
Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
Slowly peel off the plastic covering around the screen.
Place it to the side once it is completely disconnected.
You may need to apply slight pressure to release the clips of the covering.
Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place.
Gently pull the webcam away from the laptop.
Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
