跳转到主内容
Sony Vaio VPCCW17FX Webcam Replacement
你所需要的
  1. Sony Vaio VPCCW17FX Webcam Replacement, Webcam: 步骤 1 中的图像 1,1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Webcam Replacement: 步骤 2 中的图像 1,1
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Webcam Replacement: 步骤 3 中的图像 1,2 Sony Vaio VPCCW17FX Webcam Replacement: 步骤 3 中的图像 2,2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Webcam Replacement: 步骤 4 中的图像 1,2 Sony Vaio VPCCW17FX Webcam Replacement: 步骤 4 中的图像 2,2
    • Remove the four rubber circles using the spudger located on each corner of the laptop.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
  5. Sony Vaio VPCCW17FX Webcam Replacement: 步骤 5 中的图像 1,2 Sony Vaio VPCCW17FX Webcam Replacement: 步骤 5 中的图像 2,2
    • Slowly peel off the plastic covering around the screen.
    • Place it to the side once it is completely disconnected.
    • You may need to apply slight pressure to release the clips of the covering.
  6. Sony Vaio VPCCW17FX Webcam Replacement: 步骤 6 中的图像 1,3 Sony Vaio VPCCW17FX Webcam Replacement: 步骤 6 中的图像 2,3 Sony Vaio VPCCW17FX Webcam Replacement: 步骤 6 中的图像 3,3
    • Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place.
    • Gently pull the webcam away from the laptop.
    • Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
结论
Tiffani Beck
于03/20/17注册
219 声望
创作了2篇指南
团队
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 1,098
