跳转到主内容
简介
In order to remove the webcam safely, be sure to take out the battery first. The webcam is located under the plastic screen cover of the laptop.
配件
没有特定配件。
  1. Turn the laptop over and orient it as shown.
    • Turn the laptop over and orient it as shown.
  2. Slide both latches to the center of the laptop in order to release the battery.
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop. Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Remove the four rubber circles using the spudger located on each corner of the laptop. Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
    • Remove the four rubber circles using the spudger located on each corner of the laptop.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
  5. Slowly peel off the plastic covering around the screen. Place it to the side once it is completely disconnected.
    • Slowly peel off the plastic covering around the screen.
    • Place it to the side once it is completely disconnected.
    • You may need to apply slight pressure to release the clips of the covering.
  6. Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place. Gently pull the webcam away from the laptop. Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
    • Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place.
    • Gently pull the webcam away from the laptop.
    • Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
结论
Tiffani Beck
于2017年03月20日注册
219 信誉积分
创作了2篇指南
团队
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 6
过去的30天: 22
总计 742
