跳转到主内容
简介
In order to remove the speakers safely, be sure to take out the battery first. The speakers are located under the bottom covering of the laptop.
配件
没有特定配件。
  1. Turn the laptop over and orient it as shown.
    • Turn the laptop over and orient it as shown.
  2. Slide the two latches towards the center of the laptop in order to release the battery.
    • Slide the two latches towards the center of the laptop in order to release the battery.
  3. Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop. Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
    • Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Using a Phillips #0 screwdriver to remove the two screws (Length: 7.7 mm) of the Hard Drive cover and place the cover to the side. Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm)  from the RAM cover and place it to the side.
    • Using a Phillips #0 screwdriver to remove the two screws (Length: 7.7 mm) of the Hard Drive cover and place the cover to the side.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) from the RAM cover and place it to the side.
  5. Using a Phillips #0 screwdriver, remove all twelve screws (Length: 7.7 mm) that hold the bottom cover.
    • Using a Phillips #0 screwdriver, remove all twelve screws (Length: 7.7 mm) that hold the bottom cover.
  6. Lift and remove the back cover.
    • Lift and remove the back cover.
  7. Locate the fan and use a Phillips #0 screwdriver,  remove the two screws (Length: 7.7 mm) that hold it in place. Lift the fan and move it out of the way.
    • Locate the fan and use a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold it in place.
    • Lift the fan and move it out of the way.
  8. Begin removing the four screws with a Phillips #0 screwdriver (Length: 7.7 mm) from the back cover. Place the cover out of the way.
    • Begin removing the four screws with a Phillips #0 screwdriver (Length: 7.7 mm) from the back cover.
    • Place the cover out of the way.
    • Be careful to not pull any wires out while moving the cover.
  9. Using a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold the speaker in place. Follow the wire until you find the ribbon cable that holds the wires and pull straight out of the connect to remove it. You are now free to replace the speakers.
    • Using a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold the speaker in place.
    • Follow the wire until you find the ribbon cable that holds the wires and pull straight out of the connect to remove it.
    • You are now free to replace the speakers.
    • There are two speakers so be sure to repeat the same steps for the second speaker.
结论
Brianna Rukes
于2017年03月21日注册
101 信誉积分
撰写一个指南
团队
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G5
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 290
