当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn the laptop over and orient it as shown.
Slide both latches to the center of the laptop in order to release the battery.
Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) that is covering the RAM.
Lift the black plastic cover to assess the RAM.
Apply light, outward pressure to the locks on both sides of the RAM.
Rotate the RAM up and slowly pull towards you to remove it.
In order to remove the secondary RAM, use the same outward pressure on the locks.
Lift and slide out the RAM to remove it from the slot.
取消:我没有完成这个指南。
与6其他贡献者
于03/30/17注册
101 声望
撰写一个指南
徽章: 2
TTU-BENNETT-S17S8G5
4 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 1,098
