跳转到主内容
简介
In order to remove the RAM safely, be sure to take out the battery first. The RAM is under a panel on the laptop and can be ejected by hand.
配件
没有特定配件。
  1. Turn the laptop over and orient it as shown.
    • Turn the laptop over and orient it as shown.
  2. Slide both latches to the center of the laptop in order to release the battery.
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Use your  fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop. Use your  fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) that is covering the RAM. Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) that is covering the RAM.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) that is covering the RAM.
  5. Lift the black plastic cover to assess the RAM.
    • Lift the black plastic cover to assess the RAM.
  6. Apply light, outward pressure to the locks on both sides of the RAM. Rotate the RAM up and slowly pull towards you to remove it. Rotate the RAM up and slowly pull towards you to remove it.
    • Apply light, outward pressure to the locks on both sides of the RAM.
    • Rotate the RAM up and slowly pull towards you to remove it.
  7. In order to remove the secondary RAM, use the same outward pressure on the locks. Lift and slide out the RAM to remove it from the slot. Lift and slide out the RAM to remove it from the slot.
    • In order to remove the secondary RAM, use the same outward pressure on the locks.
    • Lift and slide out the RAM to remove it from the slot.
结论
Mia Martinez
于2017年03月30日注册
101 信誉积分
撰写一个指南
团队
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 9
总计 790
