跳转到主内容
简介
In order to remove the screen safely, be sure to take out the battery first. The screen can be replaced once you remove the plastic cover located on the back of the laptop with all screws removed.
配件
没有特定配件。
  1. Turn the laptop over and orient it as shown.
    • Turn the laptop over and orient it as shown.
  2. Slide both latches towards the center of the battery to release.
    • Slide both latches towards the center of the battery to release.
  3. Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop. Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Remove the rubber pads on all four corners of the screen bezel using the spudger. Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver.
    • Remove the rubber pads on all four corners of the screen bezel using the spudger.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver.
  5. Remove the screen's plastic bezel.
    • Remove the screen's plastic bezel.
    • You need to use slight pressure to release the clips.
  6. Remove all four screws (Length: 7.7 mm) using a Phillips #0 screwdriver. Make sure to hold the screen while removing the screws so it doesn't fall. Using your thumb, carefully lower the glass and place it on the keyboard.
    • Remove all four screws (Length: 7.7 mm) using a Phillips #0 screwdriver. Make sure to hold the screen while removing the screws so it doesn't fall.
    • Using your thumb, carefully lower the glass and place it on the keyboard.
    • Do this slowly to avoid damaging the screen.
  7. Pull off the tape and disconnect the display cable connector by gently sliding up to remove it from its socket. Pull off the tape and disconnect the display cable connector by gently sliding up to remove it from its socket.
    • Pull off the tape and disconnect the display cable connector by gently sliding up to remove it from its socket.
  8. The screen can now be removed.
    • The screen can now be removed.
结论
另外一个人完成了本指南。
Seowon Song
于2017年03月20日注册
113 信誉积分
撰写一个指南
团队
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G5
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 5
总计 755
