当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that hold the hard drive in place.
Use the tab to slide the hard drive away from the laptop.
Set the disconnected hard drive away from the laptop.
Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that cover the hard drive.
Use the tab to pull up on the metal cover and remove it.
You are now free to replace the hard drive.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
