跳转到主内容
Sony Vaio VPCCW17FX Hard Drive Replacement
你所需要的
  1. Sony Vaio VPCCW17FX Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the two latches towards the center of the battery to release it.
  3. Sony Vaio VPCCW17FX Hard Drive Replacement: 步骤 3 中的图像 1,2 Sony Vaio VPCCW17FX Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Hard Drive Replacement: 步骤 4 中的图像 1,2 Sony Vaio VPCCW17FX Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the two 7.7 mm screws from the hard drive cover and place it to the side.
  5. Sony Vaio VPCCW17FX Hard Drive Replacement: 步骤 5 中的图像 1,3 Sony Vaio VPCCW17FX Hard Drive Replacement: 步骤 5 中的图像 2,3 Sony Vaio VPCCW17FX Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that hold the hard drive in place.
    • Use the tab to slide the hard drive away from the laptop.
    • Set the disconnected hard drive away from the laptop.
  6. Sony Vaio VPCCW17FX Hard Drive Replacement: 步骤 6 中的图像 1,3 Sony Vaio VPCCW17FX Hard Drive Replacement: 步骤 6 中的图像 2,3 Sony Vaio VPCCW17FX Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that cover the hard drive.
    • Use the tab to pull up on the metal cover and remove it.
    • You are now free to replace the hard drive.
结论
Tiffani Beck
于03/20/17注册
219 声望
创作了2篇指南
团队
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 1,614
