跳转到主内容
Sony Vaio VGN-SR140E CD/DVD Drive Replacement
你所需要的
  1. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: 步骤 3 中的图像 1,2 Sony Vaio VGN-SR140E CD/DVD Drive Replacement: 步骤 3 中的图像 2,2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, CD/DVD Drive: 步骤 4 中的图像 1,1
    • Use a Phillips #1 screwdriver to loosen all four screws. These screws are secured to their covers with retaining clips.
  5. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: 步骤 5 中的图像 1,1
    • Lift the two covers with a fingernail or plastic opening tool from the sides the screws were present. Two tabs are securing the covers on the side opposite the screws.
  6. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove both 6.5mm screws and set them aside.
  7. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: 步骤 7 中的图像 1,1
    • Gently slide the CD/DVD drive out of the laptop.
结论
Jeremy
于03/18/15注册
722 声望
创作了4篇指南
团队
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G6
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 963
