跳转到主内容
修复你的物品
维修的权力
商店
简介
Removing the battery is the first step in servicing or replacing any other component. The battery is locked in the computer but it is easy to unlock and slide out.
配件
没有特定配件。
  1. Turn the laptop over and orient it as shown in the figure.
    • Turn the laptop over and orient it as shown in the figure.
  2. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  3. Slide the lock latch to the right to release the battery lock.
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  4. Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop. Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
结论
To reinstall the battery, follow these steps in reverse order
William Thomas
于2015年03月18日注册
125 信誉积分
撰写一个指南
团队
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G6
2 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 4
总计 758
