跳转到主内容
Sony Vaio VGN-TXN25N Keyboard Replacement
你所需要的
  1. Sony Vaio VGN-TXN25N Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Take out the screw in the center of the computer.
  2. Sony Vaio VGN-TXN25N Keyboard Replacement: 步骤 2 中的图像 1,1
    • Flip the computer right side up.
    • Open screen so that keyboard is visible.
  3. Sony Vaio VGN-TXN25N Keyboard Replacement: 步骤 3 中的图像 1,2 Sony Vaio VGN-TXN25N Keyboard Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to gently lift the keyboard at a corner.
    • Make sure you get below the keyboard itself and not just the keys.
    • Slide the tool around the perimeter of the keyboard and it will start to lift.
  4. Sony Vaio VGN-TXN25N Keyboard Replacement: 步骤 4 中的图像 1,2 Sony Vaio VGN-TXN25N Keyboard Replacement: 步骤 4 中的图像 2,2
    • Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer.
    • Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
  5. Sony Vaio VGN-TXN25N Keyboard Replacement: 步骤 5 中的图像 1,3 Sony Vaio VGN-TXN25N Keyboard Replacement: 步骤 5 中的图像 2,3 Sony Vaio VGN-TXN25N Keyboard Replacement: 步骤 5 中的图像 3,3
    • Locate the ribbon cord behind the keyboard.
    • Locate a brown clamp attaching the keyboard to the computer.
    • Use a plastic opening tool to lift the clamp and release the cable.
    • Now the keyboard can be pulled away entirely.
结论
Austen
于04/03/12注册
32 声望
创作了2篇指南
团队
Cal Poly, Team 5-3, Forte Spring 2012 Cal Poly, Team 5-3, Forte Spring 2012 的会员
CPSU-FORTE-S12S5G3
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 2,068
