跳转到主内容
简介
If the LCD Display Screen is black, cracked, or has colored lines running through it when the computer is on, the screen is broken. Follow these instructions on how to install a screen
  1. Place the computer on a flat surface with the top facing up. Open the screen.
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Locate the rubber screw caps at the two bottom corners of the screen. Use your finger to remove the rubber screw caps. Use your finger to remove the rubber screw caps.
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  4. Locate the two screws, one on each bottom corner. Unscrew the screws with a Phillips head size #0 screwdriver.
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  5. Use a plastic opening tool to gently lift the plastic casing that borders the screen. Pop off the casing by working the tool around the outside of it. Wiggling the tool may be required. The casing could be fitted snugly.
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  6. Carefully flip down the screen so it rests on the keyboard. Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection. Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  7. Remove the screen.
    • Remove the screen.
结论
另外一个人完成了本指南。
Andrew Ricker
于2012年04月04日注册
71 信誉积分
撰写一个指南
团队
Cal Poly, Team 5-3, Forte Spring 2012 Cal Poly, Team 5-3, Forte Spring 2012 的会员
CPSU-FORTE-S12S5G3
5 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 13
总计 3,052
