跳转到主内容
Sony Vaio PCG-4G1L Keyboard Replacement
你所需要的
  1. Sony Vaio PCG-4G1L Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the computer and disconnect the charging cable.
    • Failing to unplug the cable can result in electric shock.
  2. Sony Vaio PCG-4G1L Keyboard Replacement: 步骤 2 中的图像 1,2 Sony Vaio PCG-4G1L Keyboard Replacement: 步骤 2 中的图像 2,2
    • Slide battery release toggle switch towards the "RELEASE" print.
  3. Sony Vaio PCG-4G1L Keyboard Replacement: 步骤 3 中的图像 1,3 Sony Vaio PCG-4G1L Keyboard Replacement: 步骤 3 中的图像 2,3 Sony Vaio PCG-4G1L Keyboard Replacement: 步骤 3 中的图像 3,3
    • Apply pressure with your thumb on the grip.
    • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
  4. Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
  5. Sony Vaio PCG-4G1L Keyboard Replacement: 步骤 5 中的图像 1,2 Sony Vaio PCG-4G1L Keyboard Replacement: 步骤 5 中的图像 2,2
    • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
    • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
  6. Sony Vaio PCG-4G1L Keyboard Replacement: 步骤 6 中的图像 1,3 Sony Vaio PCG-4G1L Keyboard Replacement: 步骤 6 中的图像 2,3 Sony Vaio PCG-4G1L Keyboard Replacement: 步骤 6 中的图像 3,3
    • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
    • Use the plastic opening tool to release the clamp.
    • Using slight pressure, remove the ribbon cable with your fingers.
结论
2等其他人完成本指南。
Cole Collins
于10/04/16注册
193 声望
创作了4篇指南
团队
USF Tampa, Team 2-3, Cagle Fall 2016 USF Tampa, Team 2-3, Cagle Fall 2016 的会员
USFT-CAGLE-F16S2G3
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 761
