简介
This guide is very easy to complete, because back in the day computers were easier to take apart! Hope you enjoy. The only thing is that I cannot find replacement RAM, so if you can find replacement RAM for this particular machine I will include you in the honorable mentions. A picture of the RAM with the label is on step 1 on the second photo.
配件
无需配件。
  1. Flip the computer over, and remove all screws circled in picture provided. Set these screws aside for later in a place they will not be lost.
    • Flip the computer over, and remove all screws circled in picture provided.
    • Set these screws aside for later in a place they will not be lost.
    • Flip the computer over and open the lid. Then take the trackpad/wrist-rest off the computer slightly but not too fast because there is a ribbon cable to disconnect. Once you have disconnected the ribbon cable set aside the assembly
    • Be careful! There is a delicate ribbon cable to detach before fully removing the assembly. Damaging/ripping this cable will render your trackpad useless.
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    • Push the two white pieces holding the RAM aside and then push the RAM up.
    • Remove the RAM from the computer and set it aside.
    • Insert your replacement RAM into the slot, then push down gently until the plastic holders click and hold the RAM into place.
    • If the RAM does not go down fairly easily when you put it in, adjust it, don’t keep pushing because that’s an easy way to break your RAM.
    • Re-connect the ribbon cable from the trackpad/wrist-rest, then place the assembly down onto it’s mount and close the computer lid, and then flip it back over.
结论
To reassemble your device, follow step 1 in reverse order.
另外一个人完成了本指南。
Aaron Cooke
于2018年08月28日注册
16,697 信誉积分
创作了22篇指南
团队
NIWOTech NIWOTech 的会员
Community
0 名成员
创作了0篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 5
总计 53
