简介
If your laptop's keys are unresponsive or dirty a faulty keyboard may be the cause. If cleaning or replacing the keys does not work, you may need to replace the entire keyboard. Before starting this guide, it may be helpful to have a secure place to put the screws after they have been removed.
你所需要的
Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
Remove seven 3mm Phillips #0 screws from the bottom of the computer.
Remove eight 5mm Phillips #0 screws.
2等其他人完成本指南。
