跳转到主内容
Sony Vaio PCG-4121GL Battery Replacement
你所需要的
  1. Sony Vaio PCG-4121GL Battery Replacement, Battery: 步骤 1 中的图像 1,2 Sony Vaio PCG-4121GL Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL Battery Replacement: 步骤 2 中的图像 1,3 Sony Vaio PCG-4121GL Battery Replacement: 步骤 2 中的图像 2,3 Sony Vaio PCG-4121GL Battery Replacement: 步骤 2 中的图像 3,3
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL Battery Replacement: 步骤 3 中的图像 1,1
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL Battery Replacement: 步骤 4 中的图像 1,3 Sony Vaio PCG-4121GL Battery Replacement: 步骤 4 中的图像 2,3 Sony Vaio PCG-4121GL Battery Replacement: 步骤 4 中的图像 3,3
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team S2-G2, White Winter 2019 Cal Poly, Team S2-G2, White Winter 2019 的会员
CPSU-WHITE-W19S2G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 50
总计 2,813
