跳转到主内容
Sony Vaio PCG-41216L Network Card Replacement
你所需要的
  1. Sony Vaio PCG-41216L Network Card Replacement, Network Card: 步骤 1 中的图像 1,2 Sony Vaio PCG-41216L Network Card Replacement, Network Card: 步骤 1 中的图像 2,2
    • Flip the laptop over to begin the process.
    • Make sure the laptop is turned off and unplugged from the power cable.
  2. Sony Vaio PCG-41216L Network Card Replacement: 步骤 2 中的图像 1,3 Sony Vaio PCG-41216L Network Card Replacement: 步骤 2 中的图像 2,3 Sony Vaio PCG-41216L Network Card Replacement: 步骤 2 中的图像 3,3
    • Remove the two 7mm Phillips #1 screws holding the battery cover.
  3. Sony Vaio PCG-41216L Network Card Replacement: 步骤 3 中的图像 1,3 Sony Vaio PCG-41216L Network Card Replacement: 步骤 3 中的图像 2,3 Sony Vaio PCG-41216L Network Card Replacement: 步骤 3 中的图像 3,3
    • Locate the networking card above the hard drive and next to the RAM.
    • Carefully pop out the two connection cables from the networking card.
  4. Sony Vaio PCG-41216L Network Card Replacement: 步骤 4 中的图像 1,3 Sony Vaio PCG-41216L Network Card Replacement: 步骤 4 中的图像 2,3 Sony Vaio PCG-41216L Network Card Replacement: 步骤 4 中的图像 3,3
    • Remove the black tape to uncover the screw underneath.
    • Remove the 3mm Phillips head screw.
    • When loosening the screw, the network card will automatically lift itself to a diagonal position. This is normal.
  5. Sony Vaio PCG-41216L Network Card Replacement: 步骤 5 中的图像 1,2 Sony Vaio PCG-41216L Network Card Replacement: 步骤 5 中的图像 2,2
    • Pull the network card straight out in the direction it is resting in.
    • Reinsert the new network card diagonally and into the same position as the previous one.
    • To screw the new network card back into place, you will need to push the network card back down onto the motherboard.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 586
