跳转到主内容
Sony Vaio PCG-41216L Display Replacement
你所需要的
  1. Sony Vaio PCG-41216L Display Replacement, Display: 步骤 1 中的图像 1,2 Sony Vaio PCG-41216L Display Replacement, Display: 步骤 1 中的图像 2,2
    • Remove the covers for the two 3mm Phillips head screws at the base of the screen.
    • Make sure the device is unplugged and turned off before proceeding to minimize the possibility of electrical damage to the device.
  2. Sony Vaio PCG-41216L Display Replacement: 步骤 2 中的图像 1,3 Sony Vaio PCG-41216L Display Replacement: 步骤 2 中的图像 2,3 Sony Vaio PCG-41216L Display Replacement: 步骤 2 中的图像 3,3
    • Use a metal spudger to separate the top cover on the back of the screen. It will be a long, thin plastic section that has the SONY logo in the middle of it. This enables the disassembly of the rest of the screen frame.
  3. Sony Vaio PCG-41216L Display Replacement: 步骤 3 中的图像 1,2 Sony Vaio PCG-41216L Display Replacement: 步骤 3 中的图像 2,2
    • Use the metal spudger on the sides of the frame to remove it from the screen.
    • Remove the four 3mm Phillips head screws that secure the screen to the exterior of the laptop.
  4. Sony Vaio PCG-41216L Display Replacement: 步骤 4 中的图像 1,2 Sony Vaio PCG-41216L Display Replacement: 步骤 4 中的图像 2,2
    • Carefully remove the screen from the supporting frame and lay it down on the keyboard of the laptop.
    • The wires connecting the screen to the body of the laptop will be exposed and fragile. It is important to proceed with caution.
  5. Sony Vaio PCG-41216L Display Replacement: 步骤 5 中的图像 1,2 Sony Vaio PCG-41216L Display Replacement: 步骤 5 中的图像 2,2
    • Locate the ribbon cable connecting the screen to the rest of the laptop.
    • It may be necessary to remove an adhesive seal in order to proceed.
  6. Sony Vaio PCG-41216L Display Replacement: 步骤 6 中的图像 1,3 Sony Vaio PCG-41216L Display Replacement: 步骤 6 中的图像 2,3 Sony Vaio PCG-41216L Display Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to remove the ribbon cable from the screen.
结论
另外一个人完成了本指南。
一条评论
content de voir qu'il ne faut pas démonter l arrière du pc pour retirer la broche de l'écran merci pour ce topic
Serge Wilhelmy - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 29
总计 899
