跳转到主内容
Sony Vaio PCG-41216L Battery Replacement
你所需要的
  1. Sony Vaio PCG-41216L Battery Replacement, Battery: 步骤 1 中的图像 1,2 Sony Vaio PCG-41216L Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop over to begin the process.
    • Make sure the laptop is turned off and unplugged from the power cable.
  2. Sony Vaio PCG-41216L Battery Replacement: 步骤 2 中的图像 1,3 Sony Vaio PCG-41216L Battery Replacement: 步骤 2 中的图像 2,3 Sony Vaio PCG-41216L Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the two 7mm Phillips #1 screws holding the battery cover.
  3. Sony Vaio PCG-41216L Battery Replacement: 步骤 3 中的图像 1,3 Sony Vaio PCG-41216L Battery Replacement: 步骤 3 中的图像 2,3 Sony Vaio PCG-41216L Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the battery cover and set it aside. Carefully remove the non-functioning battery and insert the new battery in its place.
    • Make sure to reattach the battery in the right position with the power port, so that the power connector lines up with the battery’s port.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 1,070
