跳转到主内容
Sony Vaio PCG-31311L RAM Replacement
你所需要的
  1. Sony Vaio PCG-31311L RAM Replacement, RAM: 步骤 1 中的图像 1,2 Sony Vaio PCG-31311L RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew.
    • These screws do not detach from the plate.
  2. Sony Vaio PCG-31311L RAM Replacement: 步骤 2 中的图像 1,2 Sony Vaio PCG-31311L RAM Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry up on the bottom plate.
    • Lift up and away from the device.
  3. Sony Vaio PCG-31311L RAM Replacement: 步骤 3 中的图像 1,2 Sony Vaio PCG-31311L RAM Replacement: 步骤 3 中的图像 2,2
    • Locate the 2 clips on either side of the RAM chip.
    • Push both of them out and away from the RAM chip. The RAM chip should pop up.
    • Slowly remove the chip from the device
    • Make note of which side the slot is on in order to correctly reinstall the RAM chip.
  4. Sony Vaio PCG-31311L RAM Replacement: 步骤 4 中的图像 1,2 Sony Vaio PCG-31311L RAM Replacement: 步骤 4 中的图像 2,2
    • Repeat Step 3 on the other RAM chip
结论
Tyler
于08/24/16注册
45 声望
创作了5篇指南
团队
USF Tampa, Team 1-1, Lacy Fall 2016 USF Tampa, Team 1-1, Lacy Fall 2016 的会员
USFT-LACY-F16S1G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 978
